Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Jun 08, 2010 8:43 am
If you have a bad lower o-ring it can definitely let fuel past the injector, wash down the cylinder walls past the piston, and contaminate the oil. We've seen it way too often on the Q45 and in severe cases, the engine can hydrolock if there's a lot of fuel getting in there. Like comatoseculture said, replace the o-rings... lubricate them with a smear of motor oil before reinserting them into the rail, and see what happens.
Good luck!
Heath
