93's TRACTION CONTROL STATUS: TRUE/FALSE
i-Zer0
Car: 1993 Q45
Still waiting for my (prev. owner) friend to send me the owner's manual to the car I bought a month ago. [Why people take these out of their new cars in the first place is something I will never understand]. But anyway I didn't know traction control was also available on some '93 models, I thought it was first avail. only on 94's and later as an option - If I am mis-informed, how do I tell if my '93 base-model Q is equipped w/ it?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Look for another throttle body in front of the one on the plenum.
Reviewing the lights in the dashboard would light up a TCS notice.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
There will also be a switch labeled TCS OFF by the armrest....
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
TCS (Traction Control) was available on the '92 Q. I own one.The button in the center console says TCS if you have it.
Or you can just go drive around in some dirt and figure it out
i-Zer0
Car: 1993 Q45
Ok- I looked at the lights in the control panel as you said - I didn't see anything w/ TCS there - you're not referring to the message center in the lower left hand corner of the instrument panel, are you? Also the throttle body you were referring to: there is a cable that routs from the dual-linkage throttle plates located at the junction where the black plastic intake duct joins the plenum around to another throttle plate linkage located on the other side (lower left side) of the plenum - there is no TCS switch anywhere in the cockpit, however - - - - - - -
3rd Q
Perelli-TCS was offered beginnig in '91 I think, one of my first Qs had it. The other thing to look for is a TCS actuator on the passenger side, between the battery and the wheel well hump, next to the black fuse box.Paul
