2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Sat Apr 01, 2006 3:18 pm
Ok, I searched, and couldn't find what I needed. I have since figured out what I needed to do, so here is a "how-to" on Wiring the S-AFC II. I have a 93 Redtop in my 93 240SX (#62 ECU), so this only applies to my setup.
Ok, This is what I have so far:
For the Redtop Engines you are supposed to use the "N3-b" diagram from Apexi. There diagram is incomplete however, so I modified it to include everything you need to know.
01. Red Wire (Ignition Power)02. Green Wire (Tach Signal)03. Brown Wire (Ground)04. Black Wire (Ground)05. Yellow Wire (MAF Output)06. White Wire (MAF Input) 07. Pink Wire (Mitsubishi's only) 08. Orange Wire (Mitsubishi's only) 09. Blue Wire (Skyline's only) 10. Gray Wire (Throttle Signal) 11. Purple Wire (Knock Sensor Signal)
Here are few pics to help out:
SAFC Wiring:
Updated N3-b:
My S-AFC II Wiring Harness:
Modified by ElNegro at 8:27 PM 4/1/2006
Modified by ElNegro at 8:33 PM 4/1/2006
