93 Q45 won't accelerate, Help!!!!
fsuqback
Car: 1993 Infiniti Q45
93 Q45 only 99K, won't accelerate, I mean it feels like when you push the accelerator, it is starving for gas. You can accelerate very slowly if you feather (depress less than ten percent, any harder and you get chugging) the gas pedal. I have tried the following, different TPS, different MAF. The Fuel pump does hum when the key is turned initially, but does not hum any other time. How can I check that the Fuel pump module is working in all three positions? Anyone had trouble with clogged catalytic convertors? Just guessing.... Previous owner did change Waterpump, but everything looks like new under the hood. I can't find any vacuum leaks. This has progressively gotten worse during the drive home after buying this Q. I am frustrated, and prefer not to tow this to a dealer, based on the other posts here. Do these symptoms sound familiar to anyone? Don't really want to just throw parts at it.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
fsuqback wrote:The Fuel pump does hum when the key is turned initially, but does not hum any other time. How can I check that the Fuel pump module is working in all three positions? Anyone had trouble with clogged catalytic convertors? Just guessing....
Welcome to the board. This might be better posted in the Infiniti Mechanic Forum. There you will find information on the voltages of the three stages.
Do you have a FSM? Do you have the TSB? Have you changed your fuel filter?
Fuel pressure is always measured after the filter.
fsuqback
Also, ECU shows Code 55, everything OK. Yes I have a FSM, but not any TSB. I don't know when the fuel filter was last changed.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
fsuqback wrote:I don't know when the fuel filter was last changed.
Then it is time to change it before starting the car again. Common OEM only, please. One unfortunate member had tar coming out of his.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The FPCU can be assumed good unless a pump has failed on it...
DId you already email me about this??? Or am I thinking about someone else?
fsuqback
Yes Wes, I have talked to you on this before. How did the Meet go? Sorry I was unable to attend.
Chris
Rex
Car: None
Will the motor rev freely when in park?
elwesso
2007 BMW M Coupe
Ok.. did you already test your MAF with a known good one??
fsuqback
Replaced fuel filter today, runs a lot better, not perfect but drivable. Thanks for all of your help. The old fuel filter looked new. Wes do you still offer a discount on NGK's?
elwesso
2007 BMW M Coupe
No i dont... sorry
Chansen
Car: Q45
sounds like it could be a few things........how about injectors?maybe filter i concursounds like maybe a fuel prob91 oct or better in the Q...premium yes plz
