93 Q45 UPPER TRANS MISSION BOLTS
93 Q45
Car: 93 INFINITI Q 45
ANY IDEAS HOW TO GET AT THESE 4 BOLTS OUT IM STUCK PLEASE HELP I TRIED SEARCHING NO LUCK
Modified by 93 Q45 at 10:02 PM 6/23/2006
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
four foot extensions.
93 Q45
TRIED THAT!! PROBLEM IS TRANS WONT DROP DOWN FAR ENOUGHTO ALLOW ACCESS TO BOLTS
93 Q45
COULD IT BE MY JACK STANDS HOLDING MOTOR FROM ROTATINGDOWN , IM ON CROSS MEMBER UNDER OIL PAN
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Please lose the CAPS LOCK key.
SHOUTING is so rude.
As is double posting. This is the correct forum, but you probably didn't search bodies and archives.
Q45tech
A 4-5 foot extension from the rear of transmission.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I merged the thread forim the Q45 into this thread and cleaned it a touch.
93 Q45
sorry i made a mess butt i am new here and well ineed the info car is in the air a 4 to 5 foot extension doesnt seem to reach the bolts its a problem of space and angles everything is unboltedand the trans only drops about 2 inches
93 Q45
maxnix wrote:Please lose the CAPS LOCK key.
have you ever been 4 bolts away from finished with half a job sorry to disapoint this isnt the only place that incorporates a search i looked for hours dont belive try it as for my typeing well it one mode all caps or all lower casehands dont work as great as they usde to been a mechanic for 20 plus years
and well ive never had this problem with a transmission not droping to allow access to uper bolts
Q45tech
You use your hand to place the swivel type socket on the bolt then the extension of what ever length is required to turn the socket. Many times we see a missing top bolt because the previous tech was lazy.
