jimbyjimb »
https://forums.nicoclub.com/jimbyjimb-u93878.html
Wed Jan 21, 2009 5:14 am
Use the manufacturers reccomended fuel on stock cars. If it calls for regular, give it regular. New vehicles are very precision tuned, and are tuned to run best at the manufacturers reccomended fuel type. Higher octane regularly run in a vehicle, unmodified, designed to run on 87 is just as damaging if used regularly as 87 would be to a vehicle calling for 92+. Manufacturers typically have standards for a reason and, unless you are a fully educated automotive professional, going against manufacturers reccomendations is a fool's errand since you have no understanding of the causes of changing the conditions on which the vehicle is designed to perform best and longest under. Immediate savings may lead to unnecessary large repair costs in the future. Foresight will serve anyone well.
