93 Q45 spark plugs
andbeyond
Car: 1993 Q45
I know you've been asked this way to often probably, but I'm just lookingfor a DIY on replacing spark plugs on a 93 Q45.
I'v been searching, found a lot of good info, but I'm new to the site
Could someone please tell me where to find a good step by step on replacing the plugs.
Also are NGK PFR5G-11 the ones I need to use.
Thanks
goody90q45
Car: 1992 Infiniti Q45 (sold)
Everything you need to know about changing plugs on your Q can be found by clicking the link below.
http://www.q45.org/sparkplugs.html
While you're there check out the rest of the Q45.org site, especially the Tech Help section. Tons of great info for the DIY'er. Good Luck.
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Speaking of Q45.org... anyone heard an update from Jesda? What is the liklehood of site being put back together? Anyone heard whether picture hosting will be back soon?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Jesda will be back by next week because he starts school again, around the same time as me!!
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
someone said i should be able to tell by the looks if the spark plug is burning rich or something it would be black.. I have pics of them.. But is there a way to really tell? Ohand BTW: The plugs i took outta there are NGK PFR5B but i replaced with NGK PFR6B-11 is that ok
CrimsonQ
Car: Purple People Eater
they all look nasty! so hows it feel with new sparkers?
goody90q45
If you've lined them up left side / right side it looks like you've allso got a leaking valve cover gasket.
All the plugs look to be pretty sooty (fouled?) on the tips so it looks like you're running very rich. What kind of gas mileage were you getting before the plug change? Compare that to your first tank with the new plugs. If you mpg isn't up in the 14-16 range you have other engine tuning issues. Good luck.
Romeo5k
CrimsonQ wrote:they all look nasty! so hows it feel with new sparkers?
DOnt ask!!! go here zerothread?id=187957
