W
unknown007 wrote:I dunno if these are right.
I bought the NGK G-Power platinum the oem ones come out to $112 and i only had $90 to spend on the gasket and plugs.
Will they still work?
They are BKR5EGP
What gasket? the 90-93 uses liquid silicone to seal valvecovers? The plugs you bought are a single platinum plug, factory correct is a double platinum plug.....yours will work, but their useful life will be shorter than the double platinum plug.....
a poor area to try and save money considering how long and difficult a plug change job can be....maybe you will get 50,000 miles out of them as compared to 100,000+ from factory plugs????
The trick is to install a sparkplug that will last at least as long as the valvecover reseal job.....then do both plugs and re-sealing as 1 job to save money and time
Your plugs will need to be gapped to .44, as they are set at .40 out of the box on that model, whereas the correct plug comes pre-gapped at .44
Hope you didnt pay much more than $3.00 per plug for those.
