93 Q45 help running 4guage amp wire to interior
unknown007
Car: White 1993 Q45 (G50)
Should be posted in sound but what they know about the Q45? JK but rather ask here.I'm not trying to drill a hole to be honest so anyways I can get it in.I'll remove the cluster if I have to or remove anything except the dash.Thanks in advance.
BLACKonBLACK98
Car: Q45, LS400, STS-V
just look for unused holes/grommets along the firewall. i would stick to the passenger side so you don't have to cross the engine bay with the wire. all else fails drill a hole and use a nice grommet.
unknown007
Drilling is the last thing I would want to do.Ah I'll check later since the engine is hott.
BLACKonBLACK98
you should eb able to find something. i prefer to drill but there's almost always somewhere to get in whether it be an unused hole or sliding in next to harnesses/lines/etc. i haven't run power wire yet or i'd be of more help.
unknown007
The 8guage I had was put through the inside of the fender then just put under the seal and so on.Now im gonna push 700rms so had to go with the 4guage.I looked and cant find anything or see.Well I guess time to drill weds.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Hah... i didn't want to drill any holes either so I ran 8 gauge between the fender on the right side....
making it fit through the set of wires through the firewalls was too much work
but I ran 700RMS ..... after the fender its all 4-gauge because thats what i started out with.
unknown007
So 4guage then attach a 8guage then a 4 gauge again? Explain please thanks.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Here is the firewall for the G50:
See this thread for more realistic pictures: zerothread?id=395616
Some one forgot to use the program I gave them.
Rex
Car: None
Almost everything's been discussed beforehttp://forums.nicoclub.com/zerothread?id=233458http://forums.nicoclub.com/zerothread?id=41624http://forums.nicoclub.com/zerothread?id=127582http://forums.nicoclub.com/zerothread?id=131155http://forums.nicoclub.com/zerothread?id=116229http://forums.nicoclub.com/zerothread?id=88813
Now those aren't "perfect" answers, but have some great info.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I ran mine through a grommet on the drivers side for the hood release cable.. worked great, ran it down the side of the interior into the trunk...
unknown007
I ran it through the firewall by the ECU.Though the rubber that plugs the hole is open a bit now I'm gonna get air through there.Anybody can draw a diagram on how to put it through the bottom of the car?I can't jack mine up it's too low. I can though monday but let me know thanks.
unknown007
