93 Q45 front alignment spacs (cant spell)
unknown007
Car: White 1993 Q45 (G50)
Looked in the FSM and it says refer to S.D.S.Any help please thanks.
BLACKonBLACK98
Car: Q45, LS400, STS-V
sds is just a page, usually at the end of the section. in my '90 fsm it's fa-22.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Tough to align just the front without establishing the 0.0° thrust angle.
qship96
Car: 1996 Infiniti Q45
You really dont even need to know the exact specs as a typical car owner, just find a good shop with a Hunter Hawkeye alignment system- the specs AND exact instructions for each car model are installed in the systems database, making adjustments easy and precise for the tech performing the 4 wheel alignment.
for those who want to be informed, the exact specs are listed in the FSM, both in the front under general specs page, and in the front/rear suspension sections.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
And those shops with the laser aligned Hunters can get that initial 0.0° thrust angle right on, not merely "within specifications."
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
maxnix wrote:And those shops with the laser aligned Hunters can get that initial 0.0° thrust angle right on, not merely "within specifications."
To everyone, you'd be surprised even how much difference having .5 thrust angle vs 0.0...
unknown007
qship96 wrote:You really dont even need to know the exact specs as a typical car owner, just find a good shop with a Hunter Hawkeye alignment system- the specs AND exact instructions for each car model are installed in the systems database, making adjustments easy and precise for the tech performing the 4 wheel alignment.
Yes, I don't know.Instead of acting like an *** teel me so for once I learn something from you.
We have a Hunter at school and my teacher knows how to use it.I rather pay when I get new tires.my front tires had bad alignment and are worn so I rotated them.Thanks.
thejapino
Car: '93 J30t
qship96 wrote:for those who want to be informed, the exact specs are listed in the FSM, both in the front under general specs page, and in the front/rear suspension sections.
Hey just told you where to find the specs dammit! He's already spoonfeeding you and now you want him to chew your food for you?
unknown007
Yes, I know he did.I refered to this comment he posted.
Quote »You really dont even need to know the exact specs as a typical car owner, just find a good shop with a Hunter Hawkeye alignment system- the specs AND exact instructions for each car model are installed in the systems database, making adjustments easy and precise for the tech performing the 4 wheel alignment.[/quote]
How did you adjust your front camber by the way?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Probably has adjustable upper links.
unknown007
Yeah.Me and my teach are gonna see how we can adjust it maybe a spacer or bracing I dunno. To me it's no biggy.
