Did you not avail yourself of the Infiniti dealer performed service history? How about the senior Infiniti technician pre-purchase inspection?mwaters wrote:Don't have much to go on with it's history.
I'll work on borrowing a laptop. In the meantime, is there any other way to determine which cylinder?ppastos wrote:If you had a lapt top you could use a program called OBD Scan Tech or Nissan Data Scan, With OBD Scan tech you can shut off each cylinder and preform a some what complete Power Balance test. But with Nissan Data Scan you can only shut off a cylinder.
Build date is 12/92ppastos wrote:The build date will be posted where the drivers door striker is.
Tested resistance again today. All are good. If clogged, how would I unclog?ppastos wrote:And I am glad that the resitance is good so one of them may be clogged.
Yes, just a little bit.ppastos wrote:Does the car shake at idle?
I paid so little for the car...the wheels and tires are worth more than I paid so it was kind of a no brainer. I figured it would be a bit of a project which is OK....I enjoy the challenge. If it were serious money I certainly would have checked off with Infinity service.maxnix wrote:Did you not avail yourself of the Infiniti dealer performed service history? How about the senior Infiniti technician pre-purchase inspection?
Yes, I understand. I made a video of my car, but can't find my video connectors to upload....I have kids that love to get in to my stuff.maxnix wrote:Very difficult to diagnose from the video some other car's engine.
I read some threads recommending Quick Clean, but the dealer didn't have it and sold me BG 109, saying it did would accomplish the same thing.maxnix wrote:MM oil is very light weight and will take some varnish and lsudge into suspension if changed within an hour or so of running after installation. Try some BG Quick Clean 15 minutes immediately beofre that change, draining immediately after shutting engine down.
There is a way to determine which one is bad, But its not recomended.mwaters wrote:
Build date is 12/92
The laptop definitely sounds easier! Or, I can probably move a PC to the garage? Will this work? If so, what to do?ppastos wrote:There is a way to determine which one is bad, But its not recomended. it involves removing the plenum (the thing with the Infiniti logo) then removing the connector to each injector, Then start the car up to see how it runs, But that will take an entire day for sure.
OK, I did that and could hear each one "tick" but no change in noise and shaking.ppastos wrote:Try giving the injectors 12V of energy from the mulitimeter, Basically reverse the conector that you use to test the injectors.
Already cleaned the MAF sensor a couple weeks ago.ppastos wrote:That could mean a clogeed injector as well, But it could also be the MAF sensor, Search on Q45.org on how to clean it.
Starts cold at 1250-1500, then drops to about 750-800 warm.ppastos wrote:What does the car Idle at?
Shakes most at idle, then no shake from about 1000 - 1500, shakes again 1500-2000 (but less than idle).ppastos wrote:Does the car shake more when at idle you rev it between 1000 and 2000 RPM's?
I'll bet I waitied too long and it got too hot. Will try again as you suggest.Q45tech wrote:The solvents in a Quick Clean will evaporate around 200F so the ideal working temperature to free the varnish is 170-<200F. If you wait too long or the oil gets too hot the solvents just evaporate leaving the varnish to replate somewhere else in engine not drain out.
