93 pickup Z24i-Clutch(slipping) question???
ahstrong57
Car: 1993 Nissan King Cab 4wd Pickup Z24i
2002 Honda Civic
I have recently purchased a 1993 King cab pickup 4wd w/ the Z24i engine, I absolutly love this truck, For the last week a buddy and I have given her a alot of TLC torward the engine, Oil change, pluggs, wires, rotor-cap, new belts, waterpump, clutch master and slave, new fan clutch,battery, front rotors, calipers,brake lines and even more, ect. The Engine Purrrrs but the clutch pedal allows you to shift into gear and drive but when i get to the 2 to 3 rpms it begins to rattle and slip. when you put it back into neutral it chatters, If anyone can tell me if it is a specific part(i.e.- pilot bearing, bearing sleeve, pressure plate,bend/warpped flywheel) or if it could be a simple as adjusting the clutch play! Thank you and look forward to hearing your input! --Adam--
P.S. I cant wait to upload the picks of her.........
rizzobc
Car: 1987 nissan hardbody
might be the throw-out bearing
seang
Car: Ford Fiesta ST
bleed the clutch damper
Saudade
ahstrong57 wrote:I have recently purchased a 1993 King cab pickup 4wd w/ the Z24i engine
Are you sure about that?
rizzobc
hey Saudade, do know where I can get a 5-speed and driveshaft for my 87 CHEEP!
