Rev_D21 »
https://forums.nicoclub.com/rev-d21-u4222.html
Fri May 29, 2009 3:32 am
Start by making sure your battery isn't on its way out. Then check battery cables for corrosion and tightness. You could have a bad connection somewhere causing excessive resistance. Start simple and work your way up. Once you confirm the cables I would turn my sights on the starter and so on.
