93 nissan D21 rattles at higher rpm
trucknewbie89
Car: 93 Nissan D21
when i start the truck, a rattling noise comes from the engine. i shift it into neutral and it disappears. it also rattles at higher rpm's when i'm about to shift into a higher gear. it almost sounds like a grinding noise. is is the timing chain? it has 91k on it and heard that they should be replaced every 100k.
RT22
Car: 1991 nissan hardbody
probably the timing chain guides, they are plastic and break and make noise
trucknewbie89
Car: 93 Nissan D21
how urgent of a repair is this?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I wouldn't drive it too long like that but it's not a 'truck down' emergency. If you let it go too long you'll be replacing the timing cover.
