t.mcginley.jr wrote:Fuel pressure should be ~43 psi at idle so something is definitely not right. I haven't heard of too many FPCU's going out, but I supposed its a possibility. I would test the pump first though. It's possible he bought a knockoff Walbro and not a genuine one, or he's lying and it's actually some cheap crap.
Also since he ran it out of gas, I would change the fuel filter too just because.
Yea found out the car sit for a while and the tank was never cleaned out, when P.O ran it out of fuel it basicly clogged the filter now I have the lean out of it now its rich..
Before I go any further I will go ahead and say the motor is new it has 40K miles on it, Coil packs were replaced ( I just did a OHM test all tested good )
I have no Service light on.. I haven't had time to check the code's manually on the ECU I will do that tonight.. But he also has some things unplugged as well he has it in a safe boost setup at 7 PSI.. But when you even get boost at that it cuts fuel, and has a bad rich smell.. Also it takes a minute to even crank the car.. He says I need to plug up the boost solenoid? to return it to stock parameters..
Also at idle she is running at 0 oil pressure, but give it gas it goes up to around 60ish..
Could this be causing the issue?
