93 maxima wont start help...
snk88
Car: 93 maxima
I got a 93 maxima that wont start. the car cranks and turns. when i disconected the fuel line from the new fuel filter, i turned on the key and no fuel came out, the fuel pump turns on i can hear it, and shuts off a like it should. there is presure because when i disconnected the fuel line from the fuel filter air just shot out of it. is the fuel pump still good?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Fuel pump is relatively easy to access. All you need to do is remove the seat bottom (it is held in place by two clips at the front outside corners). It'll probably be tough to break loose if you've never removed it before, but that's the worst part of the job. After the seat bottom is out, you can see the access porthole that was hidden beneath it. Open that, and you gain access to the fuel tank. There's another access lid on the tank itself, to which the pump is attached. The actual tank access lid has a rubber o-ring that you want to be careful not to drop into the tank...you can probably reuse it but may want to have a replacement on hand just in case.
Once the pump is out, you can test it in a bucket of water where you can see if it's actually flowing anything.
Don't forget to make sure you've relieved fuel pressure before disconnecting the pump (which sounds like it probably isn't an issue for you here).
snk88
Car: 93 maxima
okay ill try that i already have the pump out ...
