mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Tue Aug 28, 2007 8:26 am
From left to right it starts at 0 and goes up in increments of 5 degrees so yours is actually pretty close to being on time of 15 degrees. I would highly recommend getting the timing belt changed though. Its a little past the recommended 60k interval or at least getting very close.
I would also check the condition of your other ignition components like the distributor cap and rotor, plugs, and wires.
Other known problems are the fuel injectors, though I believe the 93's were supposed to have the updated injectors so they should be ok.
