Greetings: I am currenty having the following issue(s) withmy 93 Maxima SE DOHC:
After morning startup until warmup (15-20 mins) the car runs very well. After the warmup the following occurs:>When the gas is depressed either from a dead stop or a almost stop, the car is very sluggish. Gas pedal can be mashed to the floor but will slowly accelerate until 2nd gear (auto) is attained (sometimes shifting to 2nd is a little jerky). When I come to an almost stop, depress pedal and will not shift down to 1st until I mash it. Even at this point, engine is still not running smooth at all. Gas consumption has plummetted from 20-21mpg city to around 10-12mpg!!!
No engine light on
3-5 times a day, when I come to an almost stop then accelerate, there is a "backfire" coming from what I think is the front right of motor. Sometimes I smell fuel after I have parked the car (not on the inside, but as I walk away).
Local mom/pop shop thinks it may be one of the injectors, but this is just a guess on their part.
I recently (1 month ago) put in new NGK Platinum plugs and a new fuel filter.
After reading online forums my mind is is completely buzzing with all "what it could be."
My problem is that I do not want to go and pay (mom/pop shop said it would cost me $300-400 to replace one injector) for what it could be, then after work is done, no fix. A friend suggested this as the Kingdom of Maxima queries and reliable answers/ solutions.
Could the problem be:MAFThe first Catalytic converter( flow issue) EGRO2 sensorInjectors
Sorry my post is so long.
Thanks in advance.
Cameron
Modified by Cam442 at 4:13 PM 7/16/2008
