93 Maxima cranks but won't start
jimmymac61
Car: 1993 Nissan Maxima
Recently acquired a 93 Maxima and after registering it took it for a ride. I noticed when starting, it sounded like it was laboring to start, as if the battery was weak. So I put charger on battery after pulling cables and cleaning them and the posts. It was a little low on charge and after an hour on 10 amp charge, it was fully charged. I put the cables back on and car has not started since. It will crank strong but will not run. Tried a brand new battery, and same thing. Is there a fuel pump rest switch hidden somewhere, or is it possible that I have damaged the computer module? Please help!! Where do I start?
JDMMAXIMA92
Car: BLACK 91 3RD GEN MAXIMA
jimmymac61 wrote:Recently acquired a 93 Maxima and after registering it took it for a ride. I noticed when starting, it sounded like it was laboring to start, as if the battery was weak. So I put charger on battery after pulling cables and cleaning them and the posts. It was a little low on charge and after an hour on 10 amp charge, it was fully charged. I put the cables back on and car has not started since. It will crank strong but will not run. Tried a brand new battery, and same thing. Is there a fuel pump rest switch hidden somewhere, or is it possible that I have damaged the computer module? Please help!! Where do I start?
I HAD THE SAME PROBLEM AS IF THE ENGINE WANTED TO TURN OFF SO I CHANGED MY FUEL FILTER AND SEA FOAMED IT THROGHT THE BRAKE INTAKE AND IT WAS THAT MY INJECTORS WHERE DIRTY SO TRY THAT OR MAYBE FUEL PUMP IS GOING BAD
audtatious
Doubt you have any problems with the computer. Problems of this nature can be related to injectors, fuel pump and maf. I do not believe there is a reset option for the fuel pump.
When you turn the car on (not cranking) do you hear the fuel pump turn on in the back?
jimmymac61
Sorry, was away for the weekend. I'll check for pump turning on this afternoon. Thanks!
jimmymac61
With ignition on, I could hear pump pressurizing fuel line. I was able to strart and run motor, but it would only start if I held accellerator to the floor. It ran very rough, but only with pedal to the floor. As soon as I let up on gas it died.????
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Make sure your MAF is plugged in tight. Try jiggling the connector to see if that makes a difference.
jimmymac61
Was able to keep motor running with foot off the gas today but had to let it warm up for 5-10 min. holding accellerator down. Was idling very rough and at 600 RPM. Almost sounds like exhaust is blocked.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
That sounds like the issue could be timing related. When was the last time you had the timing belt changed? How many miles on the car?
jimmymac61
Timing belt and water pump done at 100k. 130k now. Almost seems like exhaust blockage. New resonator installed just before I noticed hesitant accelleration. Cat is still original, I'm wondering if it may be clogged. Might try to separate exhaust just after resonator this weekend to see if that's it.
