guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Thu Jul 14, 2005 3:36 am
The threads strip easily because the head is aluminum, the bolts are steel and are much stronger than the threads in the head. Once it gets nicked or bent, aluminum gives up quick. It works ok if left alone, but if you overtorque the bolts or remove them frequently the threads just dont last.
If you want to save some time and expense and have almost as good a repair, get a 1/4 tap and the correct length 1/4 bolts. The 1/4 inch tap will go right into the existing stripped hole without being re-drilled, is cheap, and readily available at any hardware store. I tapped the 3 center and 2 front holes in about 2 minutes. I dont think I spend $5 on the entire repair and was done in no time.
I'm not trying to talk you out of doing the helicoil, because that would be the stronger and 'better' repair, but its not really necessary in this case. These bolts arent (or SHOULDNT be) torqued to more than a few ft/lbs, so unless you take off the valve cover every other week, retapping the head will be plenty strong.
