seang wrote:ECU is under passenger seat.
Yes I found the ECU. I took the whole bench seat out to give me room.
So does anyone have experience doing this swap? The computers have different connectors. 97 Truck has bires running from ECU up thru firewall to engine. But my problem is it also branches back under dash and is hooked to gauges and who knows what? Looks like I will have to strip dash and untangle this mess.
Anybody short cut and just use ECU and cut and solder connectors at engine?
Distributor is diff. plug.Injectors look to be same plug.
Just looking for easier way, not wanting to rewire entire truck if I don't have to.
