93 KA24DE part not listed in FSM?!
Dr.Noisewater
Car: 93 240sx KA24DE
I'm looking for the name of the "oil squirters" that are at the bottom of each cylinder between the crank and connecting rod. It looks like a small bathroom fixture that sprays oil on the connecting rods I think?????? Any help guys??????? My block is apparently missing them!!!! Oddly... :blush:
zachattack_5491
Car: Pignose S13 Redtop SR
Courtesy Nissan has them listed as 12121 and 12121M. I couldn't find them in the FSM either, that's weird.
http://www.courtesyparts.com/240sx-part ... _1423.html
Dr.Noisewater
Thanks so much. However whats the difference between the two? I cannot tell.
Dr.Noisewater
I cannot seem to find them much cheaper any where else. I assume the quickest way to grab some from a junkyard would be to drop the oil pan; but can a crank drop with out having to remove the entire block from the car??????? If so I would much rather do than then spend $45.00 bucks on four piston oil jets. :ohno:
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
enable your PMs, mang.
breadbox
89 Koop
84 720 4x4KC
still won't let me pm you. IDK.
So you saw my last post so I'll just talk to you here.
"What all do you have for a 5spd swap?
I already have a flywheel and clutch somewhere in my garage.
I would love another trans/crossmember and clutch master cylinder/hardline."
