93 ka in a 96
XcreatureX
Car: 96 240sx SE
would it work? OBDI to OBDII i am not sure what is different on just the motor i can get one for cheap and might build it if i can use it
Seth
TheOne
Car: 93 240sx FB
you have to use the 96 intake/exhaust manifolds, and maybe some parts for the head(the back of it there's like a panel that has a bunch of vacuum lines i believe)
XcreatureX
Car: 96 240sx SE
so basicaly i could use the block no prob?
Seth
masticatingcow
Car: 94 Mazda FD3S
Yes, the blocks are the same.
cyanide
is there anything else u would need except what he mentioned up there?
masticatingcow
Car: 94 Mazda FD3S
Not really. Internally, both motors were/are the same.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
To be exact, to put a '93 motor into your S14, you need:
The S13 block/head, valve cover, front covers, etc...
Then just use EVERYTHIG else form your S14...intake and exhaust manifolds, wiring, ECU, MAF, sensors, etc...
The S13 ('91 - early '93) cams are better, so keep those in the new motor.
- Brian
