Hi all, this is the progress report on my valve replacement in my 93 J30t. I've found a great amount of resources that I'd like to share to anybody who might be doing this job. The engine in the J30 is a VG30DE, the same (essentially) as a Nissan 300zx. Much of the information about the Z can be applied to the J, engine-wise.
http://www.pexcom.com.au/z32cms/e107_pl ... ontent.342 This link is an excellent guide to removing the cylinder heads, which contain the valves.
Youtube searches for 'vg30de', 'J30', '300zx', 'head gasket', 'upper plenum', 'valve cover', 'cylinder head', and 'timing belt' helped.
NICO forum search for any of the previous key words. Be amazed.
Ebay has some fairly economical head gasket/valve replacement sets.
In the FSM:
EM 7,8,14,15-23 (timing belt), 26, 27-36 (cylinder head)
EF&EC 6-10 (ECCS component location, vacuum hose drawing)
FE 6 (tells you there's an O-ring to be replaced between the exhaust manifold and exhaust tube)
ST 26 (power steering pump)
EL 136 (engine control harness)
A 10mm hex bit (H10) is required to remove the cylinder head bolts, and there's also an associated washer to be removed with the bolt. Careful, they like to slip around inside the head.
Removing the 14mm nuts from the exhaust manifold to front exhaust tube was difficult on the passenger side, as the exhaust tube is somewhat in the way, and required a deep socket and extension.
It's easier to just take out the EGR valve and tubing, than try to work around and pull out later. Most of those are 10mm and 12mm, and in very annoying spots.
There are seals that need to be replaced, hence the gasket replacement set. I'll be doing a full replacement, though at the least, these will be required:
4 camshaft oil seals
2 head gaskets (block to head)
2 intake gaskets (head to lower intake manifold)
1 plenum gasket(?) (yet to find a name for this, it goes between the upper plenum and lower intake manifold)
2 intake valve cover seals
Liquid gasket (exhaust valve cover)
24 valve oil seals
O-rings and seals to EGR tubes
So, I'm down to the cylinder heads, and have removed the head bolts (plus the tiny 10mm M6 bolts) and exhaust manifold bolts, as well as the power steering pump. Once I lift the heads away from the block, I plan to take them to a shop to have the valves replaced, and then I will do the rest of the rebuild. That's all for now, comments and helpful tips appreciated.
