93 J30 with the front passenger window stuck in the down pos
RobertsJ30
Car: 1993 Infiniti J30
I have a 93 J30 with the front passenger window stuck in the down position.
I removed the inside door panel.
I tried to push the window up by hand but it won’t move.
I can’t afford to fix it right now. Can someone tell me how I can push it up (then I’ll prop it up so it won’t slam back down)
Thanks,
Robert
Mkiisupra
Car: 95 Infiniti J30t
Youll need to pull the window from the top with your hand while using the switch to bring it up.
RobertsJ30
Oh, sorry, I meant to add that it's stuck down because the switch doesn't work. No clicking or humming sound. Just quit working after I rolled it down..
Thanks for the response!
fourdrinie
Car: 2019 Q50
if you truly think the switch is bad, bypass it...run a jumper wire from before the switch to after the switch...that should allow you to put the window in the up position...or run a wire from battery to the window motor....
jaimster
Car: 1995 j30
i would remove the door panel , disconnect the window's motor connection to the window relay. them get a 12v or 18 volts drill battery connect 2 from the battery to the actual motor's wires plug. if the motor still good the window will move reverse wires for opposite direction . if motor dont move - well them there are 2 screws holding the window's glass to the regulator loosen those 2 the pull the window from up and out. hope this helps
jaimster
Car: 1995 j30
