GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Sun Dec 21, 2008 6:31 am
Too much fuel or not enough air. Possibly a dirty/sticky IAC valve, leaky injector seal, dirty throttle bodies that aren't closing fully, a mis-adjusted accelerator or cruise control cable or faulty TPS?
Holding the accelerator pedal to the floor while trying to start the engine, fully opens the throttle bodies, allowing the maximum amount of air in and may signal the ECM that the engine is flooded (if the TPS is working properly).
It's also important to remember that when starting a J30 nornally to simply turn the ignition key, with no pressing of the gas pedal at all. The engine should crank for probably less than 5 sec, before it starts and then idles between about 1,500 and 1,800 rpms.
After things are fully warmed up, the engine should idle at about 650 rpms in Drive, sitting at a full stop with your foot on the brake.
