93 J30 transmission problems - Help Please!!
swp66
Car: 93 J30
I have a 1993 J30. This is my first Infiniti and it was love at first sight. I was smitten after the first test drive. I was driving home from work the other day and turned a corner and the transmission started slipping. I have had no problems prior to this. I pulled over and shut of the engine, waited a few minutes and everything seemed fine for about another couple of miles and the same thing happened again. I shut it off again and waited and now the transmission will not engage in any gear. No reverse no drive, nothing. I ran the Self Diagnostics and the light starts flashing, but there are no pauses or any changes in flash length. It just blinks very fast. At the suggestion of the local Infiniti Dealer, I changed the transmission filter and fluid. The old fluid was red and did not smell burnt. The filter was actually fairly clean, there was some buildup but not bad. I checked the pan for metal shavings and did not see any. Everything looked really clean. I do not have any transmission service records. (I bought this car from the original owner and he took very good care of it. Engine service has been well documented, just can't find anything on the transmission) Can anyone tell me what to try next? Any suggestions would be greatly appreciated. This is an excellent forum by the way, probably the most informative forum I have ever joined.
thanksScott
Modified by swp66 at 12:54 PM 12/30/2009
driverdriver
Car: NICO's longtime resident Canuck!!!
You most likely need a new rev sensor. Its a known age related transmission issue that doesn't usually throw a code. If that doesn't fix it you need a transmission rebuild.
swp66
Car: 93 J30
thanks for your response. I pulled the rev sensor off and will have to go to the dealer to get one. One question, if you start the car and try and put it in gear now do you think it would go into gear? I am not going to try it, just curious.
thanksScott
yodawill2000
Car: 94 Infiniti J30
Without a sensor I highly Doubt it.
thall1967
Car: 1993 Infinti J30t
I have a similar problem! My J30t will go forward but it will not go in reverse! Can to give me any help?? I brought a Upper Automatic Transmission Solenoid to get installed this week. I hope this works? Re building a trans can cost 800.00 right???
driverdriver
Can the actual shifter mechanism actually shift?
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
what is part number for this? i saw where this is in the service manual. right now my transmission will hit rev limiter in first and when cruising around town it seems to have a hard time finding which gear it wants to be in.
