93 J30 trans problems Need help bad!!!!!!
dosomthangs
I replaced the trans 2 times and I'm geting the same results. I was told that it can be the transmission cpu. where can I find that and do you no what it looks like?
Modified by dosomthangs at 5:36 PM 10/31/2005
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
try the driver's kickpanel, at least that where it is on the Q's. might help you get response if you elaborate on 'the same results'.....
dosomthangs
The car drives however when your in first the rpm goes up to 4-5 before it shifts but once out of first gear, its fine you kind of have to drive it like a stick and ease of the gas to trick it to shift but its been like that since I brought it about 2 years ago with all thre trans I put in. I replace the engine once as well it has a 95 ingine with a 97 trans could that be the problem.. but I put in a 93,94 and 97 trans and I think its all the same... Its just been bad news since I brought it. something draining the brand new batt after two days. took it to the dealer and they couldn't find out the problem...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
What is it doing? did yo upull yout TCU codes?
Q451990
Definately sound like it could be the TCU. Could also be the TPS (Throttle Position Sensor) or any number of things. I don't know enough about the differences between the 93 and 95 engine... did all of the connectors match up or were the sensors different?
Heath
dosomthangs
Yeah everything matched up just right.. I'll have to check on the TPS I just got a TCU and I'm going to try it out to see if it works..
Thanks...
dosomthangs
elwesso
2007 BMW M Coupe
I merged this thread with the one in the J30 forum.
dosomthangs
Thats cool... Hey how do you pull the TCU codes?
elwesso
2007 BMW M Coupe
Here you go, enjoy.....
elwesso
2007 BMW M Coupe
How to interprit the codes:
There are going to be a series of flashes..... The flash that is the longest is the code that you are concerned with...
For instance code 5 would look like this -- -- -- -- ---------- -- -- -- being that the 5th flash is the longest.. the light wil blink a total of 12 times.
Code readouts1. Revolution sensor2. Vehicle speed sensor3. Throttle position sensor4. Shift solenoid A5. Shift solenoid B6. Overrun clutch solenoid7. Torque converter clutch solenoid8. Fluid temp sensor or AT control unit powersource malfuntion9. Engine speed signal10. Turbine revolution sensor11. Line pressure solenoid12. Engine control circuit
let us know what you come up wiht and we cna go from there!!
