Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Apr 22, 2003 6:52 pm
The transmission mounted speed sensor [generator] generates a variable frequency which is sent to speedometer which contains a D/A convertor which translates the driveshaft rpm into a 0-5 volt signal for the speedo volt meter and steering, tcu, and ecus.
The [replaceable] plastic gear on the speed sensor sets the ratio vs the differential gear and tire diameter so that the speedo volt meter reads correctly.............x driveshaft rpm equals y volts.
As I remember you can get Nissan speedo sensor gears in 4-5% increments for 3.54, 3.69, 3.90, 4.08 diffs plus 2.8, 3.31 and others.
