Danz32tt »
https://forums.nicoclub.com/danz32tt-u88306.html
Sun Feb 03, 2008 11:25 pm
Hope you guys can help me out.
93 J30 with a bad shudder at 22- 2400 rpm 3 or 4th gear but only at around third to half throttle. Standing start with full load it will go all the way up reasonably smooth even if you hit the brakes at the same time to hold it around that 2200 range but if you let off on the gas at that rev area and then continue the shake starts instantaneous.Stall tests are fine and smooth.Car runs and shifts perfectly fineDead stop hold the throttle at 1500 or when its started cold on fast idle and ride the brake as soon as the car moves ever so slowly the vibration comes in although much less agressively but at the same frequency or so it seemsand seems to be only when the car physically starts to move
Brand new aftermarket drive shaft including center bearing and quadruple checked and balanced and .010 out of round of rear shaft from my dial. trans overhauled just over a year agonew plugs irridiumsI have swapped all 6 coils with used ones just to see if any differenceConsult came up no fault found on trans or engine codes (go figure)
I was thinking possibly lockup circuit in torque converter malfunction?? or internal trans failureThis is a weird one as it feels just like a center bearing failure
Any help guys??Thanks,Dan
