93 J30 passenger door cannot open from outside...
thisunreal
but the door opener works well inside and also the power lock is fine. What shall I do?
any advice will be appreciate.
Adam
Modified by thisunreal at 2:14 PM 11/24/2004
driverdriver
Car: NICO's longtime resident Canuck!!!
This is the first time, I've heard of an issue like that. Maybe there is a short or wire disconnect or frayed. The other J owners will be around here shortly with possible ideas.
Welcome to the forums!!! Another Torontonian!!!!
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
you may have dislodged the rod from the outside handle to the door latch, or broke the mount point.
you have to remove the door panel and check the control rod.
thisunreal
IvoryJ30t wrote:you may have dislodged the rod from the outside handle to the door latch, or broke the mount point.
Thanks guy.I have tried to take apart the interior of the door but failed to do that. Is it connected by a set of one-time plastic jointed screws?Anyone has a chart or photograph that can show how to release the door?
Thanks in advance!
thisunreal
driverdriver wrote:This is the first time, I've heard of an issue like that. Maybe there is a short or wire disconnect or frayed. The other J owners will be around here shortly with possible ideas.
Thanks!
As I took a deep look into it I didn't think it was an electronic problem. It seemed like a pure mechanic problem.
IvoryJ30t
