Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Sun Feb 22, 2009 5:40 pm
Are the turn signal bulbs all good?
I would replace EVERY exterior bulb you can beside the headlights (There cheap so don't complain), Clean the sockets with electrical parts cleaner then put a little bulb grease.
That might solve your problem, But to my knowledge there isn't a "Hazard relay" there is only a switch, wire and lights. You can go through the wiring diagram and I can guarantee you you won't find a "relay" in there for hazard lights.
Plus as i said while working on my cars dash i removed the hazard switch and I went for a joy ride and when the time came to turn I then saw I had no turn signals.
And FYI (For Your Information) a switch is a relay.
Please see page EL-41 if you care to see the wiring diagram for the turn signals/hazard lights.
