beklear »
https://forums.nicoclub.com/beklear-u188054.html
Thu Jan 09, 2014 1:30 pm
Hello All. Shoutout to Swimshark for all of your help. Over last 3 months J30 CEL has been intermittenly throwing code 43 (TPS) . I change TPS (non OEM) to a new aftermarket but not getting the .05 reference voltage from ECU to set TPS. What's strange is that transmission shifts normally after several clicks of ignition switch on a warm day but on colder days transmission doesn't shift until hitting 3000 rpms. A mechanic measured ECM voltage output from back of ECU for TPS and it showed a negative .05 reference to TPS. Could this be a sign of a bad ECU or relay issue? If anyone has experienced this please reply. I also need a good refferal to a competent Infiniti tech in NY or NJ who's familiar with a 1993 J. Went to one dealer and they can't diagnois '93. No FSM on their system.
Thanks
