x2RED_DET wrote:Interesting that you say you can use a RWD SR, which I have never heard of before. Logically if you look at the two motors, the intake would be facing the wrong way for starters because the throttle body for the rwd motor is on the opposite end. Then there is the issue of the distributor. I would like to see pics of this swap myself. If you are using the a silvia ecu, then that is probably you culprit and another issue.
