to NICO!
Please take the caps lock key off for your next post. Posting in all caps is considered to be SHOUTING in the forum world.
I don't think your problem is centralized - these are all separate systems on the early Q45. The sunroof issuse sounds like the clutch is slipping - or perhaps broken cables. Can you get it to move by gently pushing it while pressing the switch?
Not sure on the locks and power windows. I suppose it's possible the switches are just unplugged? You can pop the power window switch cluster up from the rear edge (closest to the arm rest) with a putty knife or flat blade screwdriver to check.
Your car came with a copy of the factory service manual in the trunk or pocket between the rear speakers... is it still there?
Heath
