93 HOnda Del Sol with H22 swap
gsr778
Ok heres the story. This morning i try to start my 93 Honda Del Sol with an H22 swap and all it would do was turn over, last night it was running just dany. So I checked the spark plugs and they were getting spark just fine. I replaced the fuel filter and it still wouldnt fire up. So then i checked the fuel pump and it to was working also. And no matter how long i tried to start the car it would only turn over. So if anyone has any ideas let me know. I know its not a nissan but i know that some guys on here are really good mechanics.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
so its sparking, and theres pressure at the fuel rail?
IvoryJ30t
use a digital voltmeter, and see if the injectors are getting voltage signals.
[WARNING- use a DIGITAL voltmeter, set to Volts DC. if you put the meter on amps, or use an analog meter, you can blow up the driver circuits on the ECU mainboard.]
gsr778
Theres presure at the rail. Ill check the injectors.
NISTECH
hold you foot on the floor and crank it for awhile 15 sec intervals. till it starts.
