93 hatch wierd nioses help please!
Syrus33
Car: 1993 Nissan 240sx Hatch
RB20DET
hi, I'm new here and i would like to hear what you guys think the problem is. i just went to go see a 1993 Nissan 240sx Hatch super hicas. When i turn the wheel fully to one side it make this knocking sound, if you put you hand on top of the shock tower, you can feel the shock jump out of place and then go back into place. it happens again when you turn the wheel back in the opposite direction. I'm thinking maybe broken shock or top plate? any ideas.
the second issue is when the car is rolling there is a wrrrrrrrrrrrrr sound coming from the rear end. if you accelerate the sound does not get louder, it just stays the same. the sound only stops once the car stops. Maybe a wheel baring, joint in the driveshaft or caliper sticking to the disk?
What do you guys think, any ideas would be great.i don't and cant get pictures because i have not bought the car yet. I just want to get an idea of what those issues could be
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
I would examine the bearing assembly and your strut top
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
front id check bushings
Syrus33
RB20DET
Thanks, I caved in and decided to buy the car, cant wait to pick it up this wednsday. I will post pic by friday. this thread can be closed i figured out what the issue was. Thanks guys
