Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Tue Aug 25, 2009 4:04 am
If you want to lower it right, spend the money and use drop spindles. Cranking down the Tbars will work to drop it an inch or so, but more than that is going to cause a terrible ride because there's no up travel left in the suspension, and it will constantly bottom out. Also, your alignment will be out.
Blocks in the back are cheap and easy.
