93 hardbody lift
punk13901
I recently bought a 93 d21 hardbody. I was looking at getting a 2" lift for it. As i was reading the lift details it said recommended tire size is 31/10.50. I am currently running 31's. Is it possible that there is already a lift on the truck or do 31's fit on stock?
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Power package D21's had 31x10.50 tires without lifts.
punk13901
So would a 2" lift really do much or should i just leave it stock?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Depends on what you want. If you do go with a suspension lift, you'll want to upgrade the steering with either a Calmini kit or at least a modified centerlink. That'll add to the cost. If you don't need the extra clearance under the frame, leave it stock. It'll get better gas mileage that way.
