whomadewho »
https://forums.nicoclub.com/whomadewho-u165512.html
Sat Jul 23, 2016 6:04 am
Been there done that on a Yota pickup. I used custom made 9:1 Pistons, oversized valves,........One major issue is going to be the ECU. Before you get started give some thought and do some research on how you are going to modify the ECU. Another problem the ECU will prevent the engine from idling properly. The bottom line when completed you are not going to gain a lot of HP. You didn't mention -2wd or 4x4 ? Rather than messing with the engine I would focus more on modifying the differential ratio and changing to a smaller tire size. You can also do some research on installing a cam degree kit. Less invasive and they are adjustable to obtain max. Hp.without any ECU modification.
