Dogfather »
https://forums.nicoclub.com/dogfather-u278136.html
Thu Oct 26, 2017 5:14 am
Changed blown head gasket and when reassembled, the engine runs rich and the mileage is about 4 mpg worse. Timing is 10' BTDC, vacuum is 22 " hg, no vacuum leaks that I can find via ear/tubing method. I say it's rich due to the smell of the exhaust.
Now the middle part of the story is that when first started, it was in limp mode - running SUPER rich and I could NOT figure out what was wrong with it. There was a ton of black soot coming out the tail pipe. Turned out that I destroyed the MAF sensor by putting a screwdriver in the MAF sensor airflow tube. Replaced the MAF sensor with a generic parts house unit. Engine seems to run fine except for the poor fuel economy and exhaust fuel smell.
During all this, I had an OBD1 code 12 - MAF (Replaced), and a code 41 - Intake air temp sensor (on order) but that's all. Here's my question: Supposing the Intake A.S. doesn't fix the rich condition, what else can I try?
