Luke »
Wed Mar 22, 2006 12:53 pm
You have the same setup as me! (93 w/ blacktop) er anyway. Check the connections that come off the ECU into the dash. There are two separate wires for coolant temp and tach. The colors are:Yellow / Red stripe - Tachometer signalYellow / Green stripe - Speedometer signal Orange - Ignition start Black (may be more than one ground) - GroundBlue / Green stripe - AC signal Blue / Black stripe - Water temp signal
I have no experience with the HUD so i don't know the known quirks they have. Mine are analog. You can also try replacing the dash coolant temp sensor. Below the throttle body, you'll see two sensors, the one with 2 wires is the ECU temp signal. The one with ONE wire is the dash temp sensor. You can go to any Nissan dealer and pick up this one-wire sensor. Just make sure you get the 91-94 KA24DE. The 95-98 S14 sensor won't be accurate. GL
