Zilverado »
https://forums.nicoclub.com/zilverado-u38750.html
Mon Mar 27, 2006 5:34 pm
Okay, that makes sense. I don't imagine power windows are a fuse problem, 'cause then none of the windows would work. Now, the sunroof may have it's own fuse - - still worth a look.
Depending how familiar you are with electrical testers, you could run some simple tests on the switches (if you can pull them out).
First off you could unplug the switch and use a 12v tester just to make sure there is a live wire running into the switch (just make sure the ignition is in the "on" position - - or the position that actually sends power to the windows). You could also run a continuity test through the switch to see if the switch is good. If all these check out, then the problem is further downstream.
Just some thoughts - make sense?
