93 cams?
palooza
Car: 1998 24sx LE
sup guys. are the cams from a 93 or (92)240sx the same as in the 91? will they add some performance to my 98 ka? thanks
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Yes, and yes.
S13 cams are the same from '91-93 (240/248), then they changed to 232/232 for the '94 'verts, and the S14s.
Tey are good for a few HP...mainly they move the HP and TQ curve over on the dyo graph abnout ~500rpm...so the peaks are higher in the revs, and the motor makes power until closer to redline, rather than drop off at ~5800rpm like it does with stock S14 cams.
- Brian
