93 auto transmission lsd?
MNVERT
Car: s13
does anyone know if the stock 93 auto transmission has a lsd in it? if it does can i still use it on the manual transmission swap?
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
first: in general, the lsd is not in the transmission - it's in the rear differential. not sure if you're confused about that or not. if i'm reading into it incorrectly, please ignore my blatent obviousness and insult to your intelligence.second: i don't think any verts came with lsd.third: if your vert happens to have lsd (most likely from it being swapped in), it will work the same with auto and manual.
94_240sx
Car: 94_240SX
MNVERT wrote:does anyone know if the stock 93 auto transmission has a lsd in it? if it does can i still use it on the manual transmission swap?
240sx is a rear wheel drive car, so differential is in the back unlike other Honda cars. All verts came with open differential.
MNVERT
Car: s13
yea i was guessing that the lsd was in the axle too.. no insulted taken i really didnt know where it was to be honest with u guys. so all verts come with open differential meaning no lsd? im a noob sorry for whack gay questions. how can u tell if a lsd is instaled on the axle or not? the guy doing my manual swaped asked me if i had a lsd i told him i dont know if i had one i wouldnt want him to take it and put it in his ride u catch my drift??
94_240sx
Car: 94_240SX
I doubt that your car has LSD. There are several ways you can check. Look at the pumpkin and see if there's orange sticker on it. Is there clunking noise when you turn at low speed? Who was the previous owner? Hardcore car guy? Does your pumpkin look like this or different? Jack up the rear end turn one wheel and see what happens. If you search, you should be able to find threads talking about identifying LSD, VLSD and open diff.
This is vert open diff diagram from FSM.
MNVERT
Car: s13
the previous owner was a old guy in the airforce but he had cross drilled slotted i rotors all around they're 400 for 4 and braided brake lines on ebay front and rear . im in atlanta right now so i cant look at my car right now ,im gonna be back home tommorow ill be able to tell than i hope i got lsd that would be sweet, i spin out in the snow pretty easy tho dont know if that helps with identifying the lsd or not. theres no clunking noise when i turn at low rpms but when i go from first into second it slips than does a hard kick but thats only in first or second is that due to a bad torque converter u think?
Modified by MNVERT at 8:39 AM 4/11/2007
Hijacker
Car: '92 240sx Convertible
'94 F-150
The easiest way to tell is to get the rear end up in the air and spin one tire. If the tires spin in the same direction, you have an LSD. If the tires spin in opposite directions (one goes forward, the other goes backwards) you have an open.
I find that method much more conclusive than looking for a sticker. Stickers tend to fall off after 15 years of road grime and weathering. Also, if someone swaps an LSD in, they may do what I did. Pu the LSD unit in the open diff carrier, which means there would be no sticker since the old carrier was used.
kc240guy
Car: gold s13 and a maxima
since its an automatic, put it in neutral. otherwise it will act like an open diff and spin both ways. i found that out after i swapped my diff in.
94_240sx
Car: 94_240SX
kc240guy wrote:since its an automatic, put it in neutral. otherwise it will act like an open diff and spin both ways. i found that out after i swapped my diff in.
That's a nice piece of info.
Quote »The easiest way to tell is to get the rear end up in the air and spin one tire. If the tires spin in the same direction, you have an LSD. If the tires spin in opposite directions (one goes forward, the other goes backwards) you have an open.[/quote]How about s15 Helical LSD? I think it acts like open diff IIRC.
Hijacker
'94 F-150
Helicals aren't technically LSDs. They're torque biasing diffs, so they act different in achieving the same effect. The spin method is meant to work on what most people would get, a VLSD
MNVERT
Car: s13
anyone tried phantom grips ?
Hijacker
'94 F-150
Stay away from those. I'd rather have a welded diff than stick one of those in there.
