blackd21vg30de »
https://forums.nicoclub.com/blackd21vg30de-u106048.html
Sat Jan 17, 2009 7:46 am
I would let the foam settle, add til full, then start the car back up and steer bump stop to bumpstop and look for leaks, the foam is what happens when air enters the system from leak, or just getting low, check your rack and pinion for leaks, the pump is a vane style, look it up on google, easy to replace bearing and seal, unless its pitted or has broke vanes, if all looks good inside, just replace bearing and seal they should be cheap, a lot better than 140 for a new one like it is here, if its shot, check out ebay or local yards, the trucks and cars share the pump just not the bracket.. hope this helps
