93 Altima black smoke and erratic idle Suggestions?
General discussion area for the U13-chassis Altima
theboz
Car: 1990 240SX coupe SR20DET, 1995 S14 SE DD, 1995 Civic Hatch, 1993 GMC 2500HD, 2004 Suzuki XL7
I have a 93 Altima with an auto transmission. I have black smoke coming from the exhaust and the plugs are fouled. I fugure it is running rich. Also the car idles erratically. Could this be the coolant temp sensor making it run rich or possibly an o2 sensor? Any ideas would be great. Thanks.
Also it is using gas like a mother. I drove about 30 something miles and it used over half a tank.
Modified by theboz at 10:12 PM 3/16/2006
wblii
Car: 1996 Nissan Altima GXE
had this same problem in my 96 GXE and it was the MAF
Bardockhan
Car: Nissan Altima GXE 1993
Same problem here?
jserrano
Car: 1994 Nissan Altima SE
Definitely check the CTS, MAF, 02, ignition timing, and fuel pressure & FPR.
nismo96ka
I had the same kinda thing and it was the O2 sensor. but why don't u get it scanned and see codes u have? that's a lot better then throwing parts at it. in my case i didn't have a check engine light but when i monitored the 02 it would sometimes not switch from lean/rich the right number of times. but seriously see if u have any codes.
Return to “1st Generation Altima Sedan (1993-1997)”
