A few things:
1. The motor is a 2.4L KA24DE.
2. It's pretty much the same (if not the same besides the FWD) as the 240sx.
Stuff you may need to ECU tune:
<snip>
OK, there are a few things needed to start tuning your KA24DE/SR20DE(T)/etc.
1. Consult Cable and Datalogging
The consult cable will allow you to data log and monitor every sensor in your car. You can DIY for cheap, or order a premade one from:
www.blazt.biz
http://www.plmsdevelopments.com/
There are a few software programs out there. Here are the best:
Nissan DataScan
http://202.43.230.118/
This is what I usually use. Supports all of the advanced Consult features, mapping tracing, wideband 02, etc. Great software, and pretty cheap at ~30 bucks for a license.
OBD Scan Tech
http://www.geocities.com/obdscantech2000/
Similiar to NDS, but free, and accepts donation. Also looks like it has some advanced OBDII functions.
Calum's Consult
Not a bad little free program, doesn't seem to be update anymore though. If anyone wants it, I will post it.
*** Please note: The KA24E ECU does NOT have consult support, and, if you wish to tune it, please convert to a U12 Stanza KA24E Ecu. It is the same thing, but has consult ****
2. Daughter Boards
Again, you can make your own for cheap, or buy a prebuilt one. I prefer PLMS's
It is high quality, and Pete is the man over there. Add 2 chips to it, and you are almost all set!
*** Note, the CA/KA24E/RB do not need a daughterboard, they are 8Bit ecu, and just require the old chip to be removed and a socket installed ***
3. Chip Burner
I use a Willems Enhanced burner. Very cheap and works! I bought mine from here:
http://www.sivava.com/buynow.php?pd=A041
For 45 bucks, its not too bad. You can most likely find one/a knock off for cheaper on Ebay
4. Wideband O2
Just about any wideband O2 will work, just make sure it supports data logging. You can NOT tune off of a narrow band. Put the disco lights away please
5. Tuning Software
Luckily, almost all the tuning software out there is FREE. First, get a HEX editor (WinHex is good). Next, you will need some basic tunning program like:
TunerPro
http://www.tunerpro.net/
I love this program. It is very advanced and intimidating at first though. The standard, no real time version is free. I will upload some Address files for it later.
RomEdit
This is a cool, poorly translated Japanese program. It rather simple and stream lined, but it goes do its job. If there is interest, I will attach it as it is no longer available.
LiveEdit
Another very basic and streamlined program, it is kind of cool as it has a built in Fuel Injector changer (ie from 270s -> 550s), and it has a built in MAF/VQ scale changer. It is discontinued by Lawrence Maroney, and, again, if there is interested I will post it up here as an attachment.
</snip>
Found that info on another site which I cannot link here.
To be honest, you may want to just do a few preventative things such as:
1. Timing chain guides (they're made of plastic and break). I used to have a 92 Nissan Stanza, guides broke. What a mess because all the guide pieces wind up in the oil pan and in the head.
2. IAC (Idle Air Control Valve) - You may want to have this replaced or cleaned if you start getting idle issues.
Other then that you can get all the bolt ons such as intake, exhaust, etc.
This motor is usually ditched though for the SR20DET.
