Gonzo »
https://forums.nicoclub.com/gonzo-u36150.html
Wed Sep 17, 2008 11:48 am
My vert hesitates/ doesn't want to accelerate from a dead stop but when it gets above 2000 rpm is drives fine. ( This happens if if I've been driving longer than 25 mins). I've checked for any vacuum leaks, replaced the plugs, wires, filter, cap, rotor, coolant temp sensor, cleaned the MAF and throttle body so far and it's still the same. I do not have access to a multimeter to check the voltage on TPS yet. Any ideas what could be causing this ? Thanks.
Here's a quick pic
