93-96 swappable parts
General discussion area for the U13-chassis Altima
nissan11
Car: '96 altima
PART.................................................YEAR / DONOR.................FITS ON
SUSPENSION / BRAKES
End Links (rear/front)..........................(90-97) Miata...................93-01
End Links (rear)..................................(99-05) Miata...................93-01
Parallel Link Bushings...........................(89-94) Maxima................93-01
Big Brake Parts (Brembo Upgrade Kit)......(02-up) Spec-V.................93-01
Front Control Arm Bushings...................(95-99) Maxima................93-01
Front Sway Bar Endlink Bushings............(95-99) Maxima................93-01
Front Sway Bar Bracket Bushings...........(95-99) Maxima................93-01
Front Lower Subframe Bushings.............(95-99) Maxima................93-97
Swaybar Endlinks................................RacingLine .ca...................93-01
Top Mount Adj. Camber........................Sentra, NX, 200sx.............93-01
2 Pistons Calipers................................(93-97) Bluebird Attesa......93-01
2 Pistons Calipers................................(xx-xx) Q45.....................93-01
4 Piston Calipers..................................(90-96) 300 Z32..............93-01
Spec-V Wheels....................................(02-up) Spec-V...............93-01
Springs........................................... ...(xx-xx) 280zx...................97-01
Hubs front(5 lug conv.).........................(89-94) Maxima................93-01
Hubs rear (5 lub conv.).........................(95-99) Maxima...............93-01
Struts............................................ ....(95-99) Maxima...............93-01
Ball Joint...........................................(9 5-99) Maxima.................93-01
Bushings(control arm)..........................(95-99) Maxima.................93-01
*Tie Rod Ends....................................(xx-xx) 240sx...................93-01
*Control Arms....................................(95-99) Maxima.................93-01
*Hubs............................................. .(95-99) Maxima.................93-01
TURBO
Turbo Manifold...................................(xx-xx) 240......................93-01
Injectors 370cc..................................(94-up) Q45.....................93-01
Fuel Pump.........................................(94-up) Q45.....................93-01
ENGINE
Motor Mount Inserts............................RacingLine.ca.. .................93-01
KA24DE (Altima 98-01)........................(98-01) Altima..................93-01
transmission
Flywheel.......................................... .(xx-xx) 240sx....................93-01
*Clutch........................................... .(xx-xx) 240sx....................93-01
*Pressure Plate..................................(xx-xx) 240sx....................93-01
INTERIOR
Steering Wheel Hub............................(95-99) Maxima..................93-01
*This part or donor car not confirmed yet.
LINKS / NOTES
--Ground Control
Miata End Links
-- (Rear) Possibly only from the Miata 99-04 only or 05. You should check into this before buying the links for your car.
Maxima Energy Suspension Paralell Link Bushings
--Nissan Courtesy Parts
--Suspension.com
5 Lug Conversition
--Pictures
--Additional Info.
Big Brake Parts
--Fastbrakes.com
Motor Mount Inserts
--RacingLine
--Inserts are made from high quality polyurethane and are designed to reduce unwanted engine movement.
Steering Wheel Hub
--For use with aftermarket steering wheel.
--Brands to look for: Sparco, Momo
--Cardomain.com (Momo Hub)
2 Piston Calipers
--Infiniti Q45 2 piston calipers require modified rotors.
--Fastbrakes.com
4 Piston Calipers
--300 Z32 swap requires a modified an Ininiti Q45 modified rotor.
--Fastbrakes.com
Return to “1st Generation Altima Sedan (1993-1997)”
